I use CDJ export function to create playlists.
But I would like to know more about how it's handled by VDJ.
For example, if I remove a playlist containing a track which is not used by any other playlist, will the track be removed from USB?
I often create a playlist with the date of gig as name, for example a wedding.
After the wedding is done I want to remove the playlist.
In order not to fill the USB with tracks not included in any playlist I would rather have them deleted.
geposted Mon 27 Jan 25 @ 10:07 am
No, the track will remain on the Usb
geposted Mon 27 Jan 25 @ 10:42 am
OK, thanks.
Is it a way to show all the available tracks on the usb?
I have so far only been able to browse by "playlist"
geposted Mon 27 Jan 25 @ 11:33 am
Just select the drive itself, and it will show all tracks on the usb
geposted Mon 27 Jan 25 @ 12:55 pm
Adion, would it be possible to add a feature like "delete files that are not part of a playlist" in CDJ export ?
geposted Tue 28 Jan 25 @ 6:44 am
+1
geposted Wed 29 Jan 25 @ 4:49 am
Feature now added to early access build 8528
"CDJ drives have subfolder to show songs that are not included in any playlist for easy deletion"
Thanks dev team
Thanks dev team
geposted Sat 22 Feb 25 @ 2:02 pm
