Hello, the FX effects on the samples do not work on virtual dj 2025 update ok, do you know why?
geposted Sun 11 May 25 @ 7:31 pm
FX on samples works fine on my VDJ2025
geposted Sun 11 May 25 @ 8:50 pm
Oh really, I have a PC with Windows 10 and Vitual DJ 2021 it works, and on the PC Windows 11 Virtual DJ 2025, it doesn't work, is there a specific setting to do?
geposted Mon 12 May 25 @ 7:58 am
I just understood why it doesn't work, when I plug in my DDJ XP2 pioneer to use the pads for the samples the virtual effects don't work on the samples
geposted Mon 12 May 25 @ 8:07 am
That makes more sense
geposted Mon 12 May 25 @ 8:54 am
You can still choose from the pad options menu to route the sample to master instead of decks, which will allow for sample effects
geposted Mon 12 May 25 @ 9:34 am
Hello Adion, thank you for your response, but in the pad option, it does not offer me master or platinum.
geposted Mon 12 May 25 @ 11:00 am
or
geposted Mon 12 May 25 @ 11:11 am
djdad wrote :
or
or
Ok my setting was good, regarding the original virtual samples which are in the audio FX, if I go to the stemSwap bank that I created it does not work
geposted Mon 12 May 25 @ 11:23 am
As shown in the options, stemswap banks are always played through the trigger deck since they replace a stem on a specific deck, so will be affected by deck effects instead.
geposted Mon 12 May 25 @ 11:26 am
For StemsSwap Banks, it depends on where you trigger the Samples and the Effects.
- when triggered from Deck pads, then use the Deck Effects
- when triggered from the Sampler view of Sideview, use the Effects on Sampler or the Effects on the MASTER mixer panel
geposted Mon 12 May 25 @ 11:28 am
OK, I understand, I will take this information into account.
geposted Mon 12 May 25 @ 11:41 am
Thank you, I will configure it. Thank you for your help.
geposted Mon 12 May 25 @ 11:43 am
How can I download it
geposted Sat 18 Oct 25 @ 8:12 am
Click the download button.
geposted Sat 18 Oct 25 @ 2:42 pm
