Topic: Anybody tried Intech Modular controllers?
Hi all!
I am thinking about trying out the Intech modular controllers as a portable DJ controller solution.
See: https://intech.studio/
Has anybody connected these successfully with VDJ?
I assume there is no ready made mapping?
Thanks!
geposted 5 days ago @ 9:02 pm
I had some Rolie gear that used the same magnetic connections, unfortunately the connection is quite fragile to disconnecting when knocked.
I think if they had something mechanical on the bottom to physically hold units together I would have kept them.
And there's no mapping, units like this come with "define the midi" software so there's no default midi that the vdj team could write a stock definition/mapping file for.
Thank you!
I understand the point. Maybe I’ll give it a try anyway.
