Topic: 2026 download
So I downloaded the 20206 update, and after I loaded it up to use, I have lost all of my crates from previous gigs that I have used in the past. I don't have access to iTunes or files from my laptop to use to use on VDJ? I'm in desperate need of some help! So I can recover all of my crates and be able to use Tidal along with iTunes and files of music stored on my USB
geposted 5 hours ago
Mine did the same thing...smh
Turns out it was the skin causing the issue. I went back to the default skin and all my songs were still there
was there
i had the same problem . so i deleted vdj now i cant install it back. Says it cant work on my computer. any suggestion?
yup it is a problem got me too we need a fix
