hi all
Has anybody found a way to change the deck colors
deck 1 blue / deck 2 red / deck 3 green / deck 4 orange
in Controller 2020 by DennYo XML
as i need them all to be blue or all red
i tried to change it but couldn't find deckcolor in the XML file
Any help will be appreciated.
geposted 8 hours ago
i supoose is same script , on the first lines , i have chnaged for blue the 1 and 2
good luck ,
geposted 2 hours ago
unfortunately its not the same, as I can't find the same lines that u sent in the xml file
geposted an hour ago
