Topic: Looking for the best software to create track number?
Hi there,
I'M looking for the best Track editor software that can add Track numbers ie. 1 - 15 to my mixes so that I can burn it properly to CD. I currenly use Nero Burner to create track number but it still creates a noise when your CD goes to the next track. I'm trying to get rid of that glitch.
Thank You!
geposted Mon 30 Jul 01 @ 2:19 pm
I read something here about Feurio which is a shareware that allow you to do what you want to do.
It seems to work fine.
I use cdr-win and just write my own cue files. It's pretty simple, and elimininates the pause between tracks.
i USE CDR-CUE. It is a simple cue sheet editor program that is compatible w/ fireburner. Very easy to use.
Thanks all, great help
I use Sonic Foundry's Sound Forge. It takes a little time, but its perfect!!
