Topic: I need help plz....
ok heres the deal..i use 2 soundcards..
soundblaster 128 + Turtle beach montego
1) im using a external mixer and want to record the mixing...
i know that option isnt possible with atomix..what program should i use...so i can get the bass lowering i do between the fading...
2) is there a plugin where u can manage the bass, treble, gain? to atomix? or something similar...the most important part is the bass....cause the built in recording is good...but if u cant take away the bass...it doesnt sound too professional..
plzz if anyone can help me...answer here...i would really really appriciate it!..
/thx
Dj Gaz
geposted Fri 09 Nov 01 @ 7:10 pm
get a decent mixer with all the eqs/gains etc...
ANY software you use for any equalising will be shit cause it will have latency, and ALL software has it, no getting round it, and thus will make your mixes sound shitty.
Get a decent mixer for about £200 and youll be sorted. go from soundcards into mixer, mixer into line-in (or rca if u have leet sound card) and record that using total recorder or something.
easy
geposted Fri 09 Nov 01 @ 11:35 pm
Yup, I've found total recorder to be pretty good, then use nero to burn to cd with separate tracks (no skips/glitches between tracks either!!)
geposted Sat 10 Nov 01 @ 12:30 am
do you have a serial munber for me i lost my??????please'
geposted Sun 06 Oct 02 @ 9:54 pm
send me for ***@***.com please
