Topic: Song data with update 2.1?
DavidPRO InfinityMember since 2001
Hi,
Will the data of your songs be affected by the new update? I have a gig tomorrow evening, and I need to know if I should wait to update or not.
thanx,
D.
geposted Fri 22 Mar 02 @ 6:00 pm
mixalisPRO InfinityMember since 2003
In atomix folder there is atomixinternaldatabase file. Copy and paste this file in a differend folder. Install new version and replace the new interlal file with your saved internal file.
geposted Fri 22 Mar 02 @ 7:27 pm
DJ RickPRO InfinityMember since 2003
I believe you only need to save the database file if you are doing an uninstall first. Just installing this new version over the old version shouldn't harm the database.
geposted Fri 22 Mar 02 @ 7:56 pm
The only infos that are not keeped from 2.0 to 2.1 are the level information.
So if you intend to use auto-gain, you should rescan your songs.
Stephane C.
geposted Fri 22 Mar 02 @ 8:27 pm
nateHome userMember since 2001
it would be a good thing to rescan your songs, definitly.
2.1 includes improved auto-level functionality - it really does work better now. rescanning them all will set the proper levels before you play the tracks.
It's easier in 2.1! Just select all the files you want to scan in the file browser window, right click, select analyze... it also seems the process is quicker in 2.1
geposted Fri 22 Mar 02 @ 9:48 pm
DJ CocoPRO InfinityMember since 2003
@Sclavel: And the shortcuts too!!!
geposted Sat 23 Mar 02 @ 1:48 am
Thanks guys!
D.
geposted Sat 23 Mar 02 @ 2:27 am
