i have a GRX500 with:
pentium 4 -- 1.60 GHz
512 MB DDR SDRAM
Bus Speed
400 MHz
Audio
Windows® sound system compatible with 3D surround
Built-in stereo speakers; monoral mini-jack microphone
30 GB Ultra ATA Hard Drive
CDRW/DVD Combination Drive
SO XP Professional
the problem my music ones every hour atleast one song skips ones ( i get a pop) it really suck
on my hard drive i have like 20 gig of mp3 all of the on well condition (i listen to all of them)
I Shut down all programs running in the background
when i run atomixmp3 i run it by itself
i love atomix it works perfectly on my destop
i wish it will work the same way on my labtop
dj yayo
512 MB DDR SDRAM
Bus Speed
400 MHz
Audio
SO XP Professional
dj yayo
geposted Fri 10 May 02 @ 9:42 pm
I have no problems on my desktop either but have to admit that sometimes during a set it skips. I have switched some things to make it run better and little tweaks have improved perfomance. Do you use a playlist or do you just search your files in the first window ? If you have a large playlist in the second window this can be rather strenuous on the cpu.
DJ Homeboy
DJ Homeboy
geposted Fri 10 May 02 @ 10:37 pm
Hmmm.... Well all i can say is that i have a Pentium II 450mhz with 64mg of Ram and it runs like a dream on mines....#
make sure you use MP3s encoded @ 128k or less for minimal CPU usage ...
geposted Fri 10 May 02 @ 10:50 pm
mmmh, is UDMA66 for your HD activated.
Check it out. Try this:
Start/execute and type regedit
go to HKEY_LOCAL_MACHINE
SystemCurrentControlSetControlClass{4D36E96A-E325-11CE-BFC1-08002BE10318} 000
Ckeck out if EnableUDMA66 is set to 1.
Please tell us if it helps
greetz,
Janosch
greetz,
Janosch
geposted Fri 10 May 02 @ 11:28 pm
Don't use MP3's less than 128kbps, because the sound quality is crap and it will give Atomix a bad name if anybody hears it....
geposted Sat 11 May 02 @ 1:00 am
No, for sure, never less than 128!!
geposted Sat 11 May 02 @ 1:15 am
Maybe it's all the Coke you've been doin. That shit falls in the key board and it's all over. Make sure you get it in your nose.
geposted Sat 11 May 02 @ 2:26 am
LOL James ! I will try what you said Janosch, but I really haven't had any problems so why mess with it. I really do think that windows has a role in this problem and that Atomix can't really do much to compensate for it. Try using smaller playlist and less video drivers resources (skins)
DJ Homeboy
DJ Homeboy
geposted Sat 11 May 02 @ 10:01 am
Ok then dont use Mp3's under 128kb then lol - remember i only got a small machine compared to you guys lol....
geposted Sat 11 May 02 @ 11:15 am
the bitrate the mp3 is encoded in shouldn't affect performance in playback. if it does in atomixmp3, then i don't know, maybe atomix engine is slow !
geposted Sat 11 May 02 @ 1:59 pm
It doesnt affect on machines over 600 mhz - for some reason that is the passline....
geposted Sat 11 May 02 @ 3:29 pm
I have AMD Athlon XP 1,8 GHz and I don't have such problemes!
AMD Rules!
P.S. It's because of your DDR SDRam.
My Friend Had such problems until he both usual.
AMD Rules!
geposted Sat 11 May 02 @ 6:14 pm
