Forum: Old versions
Topic: Virtual Dj locks up...
I've been having this problem now where virtual dj just locks up and crashes. when i try to scroll down to look for songs it locks up and the song title and some pictures (the liitle cd icon next to each song) become jumbled up..
i dont know what this is, so i reinstalled windows and still the same. :(
can anyone help me on this.
my PC specs are:
P4 2.4ghz
512 ram
etc etc..lots of hard disk space, windows xp pro.
pls help
geposted Wed 10 Dec 03 @ 12:32 pm
kaleoPRO InfinityMember since 2003
You have a P4 HyperThreading I presume (2.4"C").
If I'm right, you can try to execute VDJ in compatibility mode for Win98. If this doesn't work better, try to disable the HT in the Bios.
Good Mix :)
geposted Wed 10 Dec 03 @ 12:58 pm
Sweeeet!!
That did it.
thanks heaps.
ps you guys gotta get that "magic" beat lock thing working and all them other fancy 'automixing' tools (dont really work, or not fast enough), cos i think its faster doing a mix by ear....hehe
geposted Wed 10 Dec 03 @ 1:01 pm
You're welcome :)
PS: You don't have to use all VDJ features but only these you want/need :)
geposted Wed 10 Dec 03 @ 1:20 pm
greydjHome userMember since 2003
Thanks for everyones help.
I have given up with Win98 and loaded XP. It now works.
geposted Mon 22 Dec 03 @ 1:32 pm
how do you disable HT???
cant find any option in my bios!
Pleeeeeeease.........
geposted Sun 08 Feb 04 @ 9:58 pm
pauljwestran, what brand/type mainboard do you have?
i need to know more details.
p.s:most of the bioses can be accessed by pressing DEL while your system is booting.
geposted Mon 09 Feb 04 @ 11:34 am
nancybPRO InfinityMember since 2004
Hi, How do you configure vdj for 98 compatability mode?
geposted Tue 10 Feb 04 @ 4:35 am
Right click on the icon of VDJ--> property --> compatibility --> in mode of compatibility: check win98
Coyote
geposted Tue 10 Feb 04 @ 4:46 am
This problem should be gone with v1.08, and for anyone who disabled hyperthreading, i recommend to enable it and see how much faster VDJ will work (try to analyse song while playing for example)..
geposted Tue 10 Feb 04 @ 12:32 pm
androidi, enabling HT 'MAY' cause audio-hickups/dropouts.
same goes for 'speedstep'.
om my intel machines i had to disable both of the features to gain clear uninterupted sound.
loading time is irrelevant since you can directly start mixing while your song is being loaded/decoded.
when i have to play a set, first i disable both features and re-enable them again after i'm finnished ;)
geposted Tue 10 Feb 04 @ 10:16 pm
austin1Home userMember since 2004
the mixing on my vdj isnt right it keeps jumping and locking do
do i need more drivers is my system compatible or could it be my souncard please help
geposted Fri 13 Feb 04 @ 11:15 am
Austin1, tell us what you have already tried. i assume you have tried to disable Hyperthreading and Speedstep in your BIOS?
geposted Fri 13 Feb 04 @ 11:41 am
no i havent how do i go about doing that ive only had it a few days .what do i do?
geposted Fri 13 Feb 04 @ 11:47 am
dont you mean hyperthreading!!
geposted Fri 13 Feb 04 @ 11:50 am
geposted Fri 13 Feb 04 @ 11:56 am
