Forum: Old versions
Topic: Herc. DJ console bug??
OjLenoHome userMember since 2003
I don't know if this is a bug or not, but is there a way to assign the DJ Console to ONLY one instance of VDJ? Cause right now when I press play (say, on the left deck), all the left decks (in all instances) start playing at once.
Thanks.
geposted Wed 10 Dec 03 @ 11:50 pm
I doubt this is a bug, both the VDJ programs listen for the controller messages and both recieve them (like they should). Thats why they start playing.... Im suprised you can start 2 instances with vdj console version.
Sorry mate, but for now there is no way to start 2 instances of the vdj console version and switch the controller between programs. The full version should enable you to select if you want to use the controller yes/no....wich is an option in the config menu.
geposted Thu 11 Dec 03 @ 12:30 am
Thats cool to know... I didn't know that was an option in the full version. Hey, I also have a DMC1 controller. Is it possible (if I get the full version of VDJ) to have one instance assigned to the Hercules console and one to the DMC1 controller?
geposted Fri 12 Dec 03 @ 8:00 pm
