Topic: y-splitter?
Hi folks, help a dumbass ooot!
Have been told about a "y-splitter", but not much....can anyone tell me the craic??
Cheers
geposted Mon 24 Jun 02 @ 1:52 am
HomeboyPRO InfinitySupport ManagerMember since 2003
A y splitter is a connection to your 1/8 inch headphone jack on your pc to 2 seperate full mono channels. Select the 1 sound card and mixer option in the control panel. You should now notice that the left player plays through the left channel and the right player through the right channel. Also you could select headphones and speaker option. This will allow you to monitor a channel while the other plays.
DJ Homeboy
geposted Mon 24 Jun 02 @ 3:45 am
aknit44Home userMember since 2002
If you have a 3D sound card, all you need to do is place your headphones in the rear channel, or line out channel, and you will be able to monitor one channel as the other plays, in stereo mode. Atomix supports 3D cards, so it's a good option too.
geposted Tue 25 Jun 02 @ 10:54 am
Yes but if your using a 3d soundcard - make sure your using the WDM driver for it...
geposted Wed 26 Jun 02 @ 1:02 am
