Topic: MP3 Songlist Creator for Mobiles?
a65reaHome userMember since 2001
All mobile DJ's out there please tell me what you use or suggest as good software to create playlists in which you can edit/tag mp3's. I need to have one so people can look over my music. I've tried music match jukebox and it doesn't work when transferring songs through a network. I've tried Collectorz MP3 and do not like it, and it doesn't work well. Please help!!
geposted Wed 10 Jul 02 @ 7:16 am
aknit44Home userMember since 2002
Your question is a little vague, but if you are talking about managing MP3 files and their IDv tags/tagging info, have a look at MP3 Tag Studio, which you can find at www.magnusbrading.com/mp3ts.
Good luck.
geposted Wed 10 Jul 02 @ 2:45 pm
If you use Winamp Player, you can use this pluggin...
it's amazing!!!!
http://perso.club-internet.fr/boyerjl/
EZ-Playlist
You can rename files from a tag
You can write tags from a filename
etc....
you can to catalog your music, specially if you're a DJ
Is a great pluggin.. and easy to use!!!!
Most important: IT WORK!!!
geposted Wed 10 Jul 02 @ 10:27 pm
The best Mp3 organizer that I've ever found is Tag&Rename. It's a great tool that does just about everything you want, from mass file renaming to creating tags from file names, both ID3V1 and ID3V2. Check it out at http://www.softpointer.com/tr.htm. It's worth your while!
geposted Thu 11 Jul 02 @ 10:26 am
