might just be me but when ever i try to download a skin 9 times out of 10 the zip is corrupted... what gives?
geposted Fri 30 Aug 02 @ 3:43 pm
It probably is just you. I've never had any problems at all downloading a skin.
geposted Fri 30 Aug 02 @ 6:00 pm
what compression utility are you using? If it's winzip, try winrar. I love winrar and use it all the time. if it's not even winzip, then try that. i've never had a corrupted skin
phatty720
dave
phatty720
dave
geposted Fri 30 Aug 02 @ 6:20 pm
I haven't too
geposted Fri 30 Aug 02 @ 6:31 pm
well it's not just you, same thing happens here. i keep geting screwed files from this site, zip files with crc errors, dll that don't work... somebody fix this ASAP!
geposted Sun 01 Sep 02 @ 2:01 am
dude you gotta at least give your system, OS, and what unzipper you're using. seeing as how it works for the majority of the user's on this site... don't you maybe think it's something wrong on your side? and not atomix? i haven't had 1 single problem ever dl'ing anything off of this site.
phatty720
dave
phatty720
dave
geposted Sun 01 Sep 02 @ 2:56 am
Try disabling any kind of download accelators, clear the browsers cache, and try again.
geposted Sun 01 Sep 02 @ 3:25 am
fixed, the problem was with the proxy server im using (webwasher). though i never had any problems with it before ...
geposted Mon 02 Sep 02 @ 2:04 am
