Would be nice to have a pitch bend function that would lower or raise the pitch while pressing a button and then return to original pitch when released.
This works great for quick out of synch corrections.
geposted Thu 18 Apr 02 @ 9:52 am
What you can do.... is to rightclick on the pitch slider with your mouse. This will bend the pitch while the button is pressed and then return to its original position when the button is released.
If the skin you are using does not perform as described above, it is because the pitch-slider in the skin is programmed to do something else or nothing at all, when right-clicking on the the sliders. You can change this in the skins XML-file and add/modify rightclick="bend" (other possible values are reset, auto, cut, and boost) to the pitchslider-elements. (Look for slider action="pitch")
Another way to bend the pitch is to assign keyboard-shortcuts in the options menu.
- Jim
- Jim
geposted Thu 18 Apr 02 @ 11:28 am
Yup, the right click in the pitch slider area is perfect for "pitch bend" It'll do exactly what you are asking about....
geposted Thu 18 Apr 02 @ 9:06 pm
