I want to use my Atomixmp3 along with turntables. When I mix from vinyl to mp3, I need to be able to beatmatch manually. The only problem is that I have a hard time trying to fine tune the pitch with a mouse. Is there any way to have a keyboard shortcut to nudge the pitch up or down in very small increments? If so please incorporate that into the next release.
geposted Sun 25 Aug 02 @ 6:27 am
Please check in the shortcut section of the options menu under shortcuts, you will find all that is needed to do all the tasks you require.
.:DJ Homeboy:.
.:DJ Homeboy:.
geposted Sun 25 Aug 02 @ 11:07 am
Either use the shortcut-solution mentioned above or find a skin with really long pitchslider (longer = more pixels = better control/higher definition)..
I know there aren't that many around and sadly I haven't been working on my own skin which has just that in over 2 months, I've just been to busy to fool around with skins :P
geposted Mon 26 Aug 02 @ 8:58 am
I looked in the shortcut section and all the pitch page up or down functions have a key represented as "NUM". What is that? I don't understand.
geposted Thu 29 Aug 02 @ 5:35 pm
Probably num lock it is found in the top left hand corner of the number pad
sPEX
sPEX
geposted Fri 30 Aug 02 @ 2:02 pm
Nooo.. that NUM stands for Numeric keypad which means + and - on the numeric(/rightmost) part of your keyboard control the pitch and holding shift while pressing the same buttons finetune the pitch..
geposted Fri 30 Aug 02 @ 6:10 pm
I Tried pressing shift and + or- and it does not work. Hmmmmm
geposted Fri 06 Sep 02 @ 6:20 am
I cannot figure it out.......please help
geposted Sun 08 Sep 02 @ 6:03 am
Are you using the numeric + and - ?
It doesn't work with the ones in the over by U , I and O, it has to be the ones by the numeric keypad and to hear a more obvious result press them without holding Shift to get a bigger change in pitch.
geposted Wed 25 Sep 02 @ 1:34 pm
