Forum: Old versions
Topic: It gives me error messages...PLEASE HELP VERY FAST!
I'm a very loyal user of Atomixmp3!
But why, why the program got to do me the worst things?!
Why is it so cruel?!
I'm trying to load a song (lots of songs!) and it gives me an error message with a code.
This are 3 error codes that i've catched:
40b752:8904458b
40b732:ca8babf3
41c291:520c61d8
40b773:4201418a
I DON'T UNDERSTAND!
Everything worked absolutly PERFECT yesterday!
I'm using Atomixmp3 v2.0
PLEASE HELP ME FAST!!!
I gotta do a private party in 2 days....PLEASE!
geposted Sun 10 Feb 02 @ 9:54 pm
I had a similar problem with one single tune (Rank 1 - Airwave) it worked perfectly then one time those kind of errors occured and the song wound never play again.
What I did was reinstall Atomixmp3 completly and then everything to this day was ok, but I lost all of the info on all the other songs that I used
If there is a simpler way I would like to hear it too....
Dav
geposted Mon 11 Feb 02 @ 6:42 am
We remember you to regularly make backups of your internal database files, so you always can keep your songs info.
geposted Tue 12 Feb 02 @ 12:49 am
Try unistalling Atomix
and then use RegCleaner to clean any registrationos of Atomix
then try to reinstall it.
It might help ..... i dont know for sure, but i do it with any programs wich get me error messages from nothere ....
It works most of the time so it might be worth of trying
Good luck
geposted Sun 03 Mar 02 @ 7:56 am
