Forum: Old versions
Topic: Static?
I've only had this program for a week, and it worked fine two days ago, but today, when I loaded a song, and pressed "Play" all I got was static, no song. I tried to play a few other songs, and same thing - static noise. Then I tried the sample songs that some withthe program - same thing.
I have a full version of the software, and it's a paid for version - not cracked.
What the hell's wrong with this thing?
I need it for my party on Saturday?
geposted Thu 10 Oct 02 @ 8:01 pm
DJ RickPRO InfinityMember since 2003
Have you changed any sound configurations? Could be a problem with your sound card or the cables.
Try playing the same track with another application and see if it's static. If it isn't, perhaps you need to uninstall Atomix, and re-install it.
Personally, I've not had this problem, so I could be giving bad advice, but if I did have the problem, that's what I would do.
Have you send an e-mail to the team with this poroblem? Perhaps they can help you.
Good Luck
geposted Thu 10 Oct 02 @ 9:30 pm
I have not changed the sound configuration.
I uninstalled it, and re-installed it.
The songs play just fine in Windows Media Player, and WinAmp.
Help!
geposted Thu 10 Oct 02 @ 9:34 pm
