If I extract skins in the atomix folder, the don´t appear in the config menu. What can I do to see and change them?
geposted Thu 22 Feb 01 @ 8:57 pm
click on the skin option in the OPTION PANNEL OF ATOMIXMP3.
Then you can normally see this skins if you use atomixmp3 1.12
geposted Fri 23 Feb 01 @ 12:22 pm
Make sure that you also extrated the file ini to the Atomixmp3 directory. Example you need Denon.bmp and Denon.ini.
Saludos
Abel
Saludos
Abel
geposted Sun 25 Feb 01 @ 4:32 am
I extracted them completly in the atomix folder (bmp + ini) but I can´t see them in the skins menu. My version is 1.12.
geposted Sun 25 Feb 01 @ 8:07 pm
Try un-installing and then re-installing atomix
-= R ! S C =-
Team Atomix
-= R ! S C =-
Team Atomix
geposted Sun 25 Feb 01 @ 10:42 pm
Hy everybody,i have problem with skins.When i download a new skins and install them,every thime when i change skin atomix is turn off.Can anyone tell me why?.I have atomix version 2.0
geposted Thu 18 Apr 02 @ 8:53 am
mladen:
If you have the 2.0 version of atomixmp3 and are trying to use skins that have a higher resolution (1024*768 and above), then that is the problem. V2.0 does only support skins with the resolution 800*600.
But if it is a SVGA-skin (800*600) that your selecting and it still shuts down the program, then try going to the top line of the XML-file of that skin and remove the width and heigth parameters (width="800" height="600") This may allow you to use the new skins, but some of the new features (v2.1) that are included in the skins will not work.
I hope this answers your question...
cheers...
- Jim
cheers...
- Jim
geposted Thu 18 Apr 02 @ 10:50 am
Can anyone tell me what version of atomixmp3 is better, 1.12 or 2.0?
By the way Jim Nordic,thanks you helped me:)))
geposted Fri 19 Apr 02 @ 9:24 am
CHEERS
CHEERS
