Forum: VirtualDJ Skins
Topic: how do i change skin?
im kinda new to this program...and im not sure how to change the skin
geposted Fri 16 Aug 02 @ 1:17 pm
First of all, you'll need some skins, but will assume that you have already downloaded some.
Unzip these files to the skin-directory which is a sub-directory for [atomixmp3].
Start Atomixmp3.
On the default-skin, there is a small button in the middle with a question-mark on it. Left-click on it.
Now you will get a list of options, and you'll find an option called "Change skins...". Left-click on it and a new window will pop-up with a list of skins that you have unzipped (pluss the default skin). Select one.
(Sorry about the lame instructions, but I don't know how familiar you are to this program.)
- Jim
PS! You should keep in mind that some of these skins require the latest version of atomixmp3.
geposted Fri 16 Aug 02 @ 4:02 pm
(nt = no text)
geposted Tue 20 Aug 02 @ 3:52 pm
what lenguaje to do of skin?
tt sarmy
geposted Tue 20 Aug 02 @ 7:54 pm
I'm afraid that I do not understand your question.
- Jim
geposted Tue 20 Aug 02 @ 11:54 pm
