Is there a color that atomix see as "transparent"?
If so, what is it? ;)
If not, there really should be!
I can think of 2 possibilities for transparency, one of which i would like to use in my design. (i dont want to give away all of my designs, but it involves buttons [chew on that for a bit ;) ] )
Something to think about mabye... a transparent color and/or a semi-transparent color.
geposted Tue 17 Sep 02 @ 1:34 pm
A good use for transparency would be for overlaying beat curves from two instances....
Both skins would be half screen height... the bottom skin would have beat curves at the top and the bottom skin would have beat curves at the bottom... both beat curves would have transparent backgrounds...
Al
Al
geposted Tue 17 Sep 02 @ 11:39 pm
Very cool idea Al,
I had an idea like that but concerning non-transparent beatgraphs just lying edge-to-edge with eachother.
Transparency is not incorporated and neither is the beatgraph styles I was thinking of for my idea (think one "fire-beatgraph" going from the bottom-border of the area and up and one "rain-beatgraph" doing the exakt opposite :)
geposted Wed 25 Sep 02 @ 9:34 am
