Hi.
I have a problem with this software.
I have 2 soundcards: Soundblaster live (3D card with front & rear outputs) and winfast 4X.
I choose 2 soundcards in the audio configuration. Also, i choose external mixtable (with hard. mix).
But both decks (left & rear) go to the same output... (the soundcard that i chose as 1st soundcard...).
I tried also to choose 3D card (the soundblaster with front & rear) but nothing again... If this could work (front & rear SEPARATE outputs) i would not have any problem, even if 2 cards weren't supported...
My settings for audio (multimedia ) in my PC are correct...
The only way to make 2 soundcards work, is to open a 2nd window of Atomixmp3, and choose there the other card. But you CANT mix like this... (Left & right deck on the same window, go to the SAME output...).
I wish you can help me...
Maybe its a bug of the software???
Maybe there is a patch to fix this???
Waiting for news...
Babis from Greece.
Waiting for news...
Babis from Greece.
geposted Thu 18 Oct 01 @ 9:40 pm
are you using the real full version? or a cracked version?
geposted Fri 19 Oct 01 @ 1:43 am
