i want to separate my big wav into tracks with no pause between the tracks.
i got some dirty sound when i am using atomix with external mixer.I have the paid version.in my headphones the sound is good but when i mix the songs then its going worse and worse is my mixer the problem?
geposted Mon 22 Oct 01 @ 2:05 am
It depends on the recording software you use. I.e. the SB recorder can cause ugly skippings.
Try to use other recording stuff first. A good alternative, but in german language, is waverec on www.waverec.de.
To split the tracks, use the track editor of your burning software. A good alternative is www.feurio.com.
geposted Mon 22 Oct 01 @ 8:05 am
And also while recording do not forget to monitor the volume of the signal you're recording.
If the mixing table's output signal is too strong, you'll end up with a scrambled sound.
Rgds,
DJ Corpse
Rgds,
DJ Corpse
geposted Mon 22 Oct 01 @ 9:06 pm
Thanx a lot:))keep good work
geposted Mon 22 Oct 01 @ 10:53 pm
CD Wave Editor works pretty good for me @ www.cdwave.com.
geposted Tue 23 Oct 01 @ 6:04 pm
