I have noticed that a lot of people are having some problems making their Soundblaster Live card work with the two outputs. I myself had some problems and tried a lot of things to finally make it work, so I tought I'd share some with you.
First, you need the full registered version of AtomixMP3, not a cracked version, because the multiple-output option isn't even coded in the demo. The crack will only get rid of the time limit.
Then, go to http://www.soundblaster.com/liveware and get the latest version of LiveWare! This may seem useless if you already have the latest drivers, but it seems that this thing makes a difference. I at first only installed the drivers without installing LiveWare and it didn't work. Even if you go in the Multimedia section of the Windows Control Panel and set it to "4 speakers", it won't work. You have to set it to "4 speakers" in LiveWare.
When you have the full AtomixMP3, the latest version of LiveWare! and of your drivers, you are ready to go. Simply go into the Sound Config section of AtomixMP3 and select "3D Soundcard" with either Speaker/Headphone/Mixer config option on the right.
I personally use AtomixMP3 along with a American DJ XDM-2221 mixer and a pair of Sony MDR-V700 Headphones and I'm having a blast...however, certainly not as much as the people who dance to my mixes. 8-)
If I've made any mistake, feel free to add you reply.
DJ Omni
http://www.productionsomni.com
DJ Omni
geposted Thu 25 Oct 01 @ 5:38 am
