Does sombody now how to solf this problem?.
I have my mp3's on a slave drive in a partition. i checked ultra dma but this is selected.
geposted Tue 23 Dec 03 @ 5:46 pm
Do you use the ID3 TAG Plugin?
Gwenn
Gwenn
geposted Tue 23 Dec 03 @ 5:48 pm
how does the id3 plugin work? is the info in the id3 tag being displayed in the track panel? is it read at analyze time or each time you select a folder. If you edit the id3 values, do you have to reanalyze your track?
please please give me some details on the plug-in!!! (I already asked in a separate topic but noone answered).
As a djconsole user I don't have access to it, but I might want to buy the full version just for getting access to this must-have functionality, if it's well implemented.
Thanks.
Thanks.
geposted Tue 23 Dec 03 @ 7:22 pm
are you using an external USB drive? if so, it is not VDJ but the speed of the drive. I had this problem with other dj softwares
geposted Wed 24 Dec 03 @ 6:17 pm
i am using the id3 tag plugin, i am going to try to disable it.
Thanxs
Thanxs
geposted Fri 26 Dec 03 @ 1:06 pm
