Forum: Old versions
Topic: I Can't Get My Update From 1.12 to 2.0
It keeps saying that my email isnt valid
geposted Thu 03 Jan 02 @ 9:57 pm
alreaHome userMember since 2003
You have to use the same e-mail that the one you've used to register. You can check it by clicking on "modify your profile"!
If it doesn't solve your problem, then mail to service@atomixmp3.com your mail adress, the date you've purchased atomix...
Hope it helps, Adrien.
geposted Thu 03 Jan 02 @ 11:29 pm
