I have been using Atomix on laptop for couple of years now.
It is a great software. My problem is, I can not get it to display full screen. My laptop is 14" and when I open the atomix program there is still an inch of open space on each side. I have tried to change the resolution on the laptop and it didn't help. Is there any way to make the atomix screen look bigger?
Thanks,
Max
Thanks,
Max
geposted Sun 03 Mar 02 @ 7:06 pm
I think I found the solution of this prob:
when you put the prog. in full screen, push on the reduce button of the soft (the first from left to right) and then left click on atomix in the task bar.
Then you'll have a black border around Atomix.
RvN
RvN
geposted Sun 03 Mar 02 @ 7:33 pm
That doesn't work. I want to have a full screen of the program on the laptop.
geposted Wed 06 Mar 02 @ 1:17 am
Try setting your monitor to 'Laptop Display Panel 1024*768'.
I had the same problem and it worked for me.
geposted Wed 06 Mar 02 @ 1:31 pm
That does not work either. Any other ideas.
Thanks
Thanks
geposted Thu 07 Mar 02 @ 1:39 am
