Forum: Old versions
Topic: RE; What happened to the db function
lpspinHome userMember since 2002
I don't mean the volume sliders. The gain buttons are a temporary change while the songs are playing. The old version had a actual read out of the volume of the songs, ie -20,-27, -18 etc. I could then go to another program, edit the volume up or down, go back to Atomix, check the results so each song was at the volume I wanted before burning to a CD. This feature is missing from the new version.
geposted Sun 03 Mar 02 @ 7:57 pm
erikkieHome userMember since 2001
I don't know.. But very interesting! Which program do you use for pitching up the volume???
geposted Mon 04 Mar 02 @ 4:23 pm
I found it!!!!! If you double left click on the desk at the "infos" you will get another screen that shows all the information plus a volume read-out.
geposted Mon 04 Mar 02 @ 5:27 pm
