I really like this program how ever I have a big problem. I am a huge user of BPM Studio which uses ID3V3 TAG system. From what I have been reading this program does not use TAG data. But what it has done is delete or overwrite BPM and other tag data. Unfortunately the BPM calculator is not even close to being as accurate as BPM Studio's. When I use Automix it comes up with totally different bpms and they are constantly changing sometimes. Is there a way to disable the bpm function in automix and stop it from over writing or deleting tag data?
geposted Fri 15 Mar 02 @ 9:22 am
Atomixmp3 doesn't use the ID3 tags at all. Is uses the name of the file: "Artist - Song.mp3"
geposted Fri 15 Mar 02 @ 9:30 am
As dams say atomix dont use idtag file. At all. The bpm change in depence of the local bpm. You can right clik on mp3 file and modify bpm. After this bpm doest change.
geposted Fri 15 Mar 02 @ 6:25 pm
I would be more suspect of BPM studio than anything, consider it's the app using the tags.....
-nate
-nate
geposted Wed 27 Mar 02 @ 8:45 pm
