Forum: Old versions
Topic: Will not open a folder from my hard drive.
Hi folks,
I have had this problem before.......When trying to open a folder Vdj has crashed.......through process of elimination I found that a file was causing the crash(was a smallish folder).....normal service resumed - until tonight! this problem has occurred again, in a different folder which I have opened before. As i stated above, this does not happen with Atomix the weak.
As Vdj recovered i let it access the internet and I was informed that v1.08 was ready ..... YIPPPEEE....this might fix my problem - NO, Santa is make believe!!
As i say, Atomix opened the original "bad" file as did realplayer and Windows media player.
This folder is fairly big so I would prefer not to have to go through them 1 by 1 to find the "dodgy" one --- Help please, any suggestion will be appreciated.
Happy Chrimbo from Ireland,
later,
Liam
by the way...I could send you the first file which crashed Vdj.....anyway you want, by post if need be.
geposted Wed 24 Dec 03 @ 10:13 pm
