Which is the best: Audiocatalyst or cd'n'go for ripping(?) CD (to transform a CD audio to mp3).
In the options I can choose beetwen Stereo and Joint Stereo.
Is there a difference????
So what do you think about the best algorithm of compression???
I must prefer LameDLL or other????
Which of these Atomix prefer to works great????
Very Thanks
Francesco
Very Thanks
Francesco
geposted Sat 13 Apr 02 @ 12:28 pm
Niether. Use Exact Audio Copy (EAC)
http://www.exactaudiocopy.de/
And use Lame to compress the wavs into mp3. Use regular Joint Stereo, NOT Forced Joint Stereo, only if your encoding at bitrates higher then 160. Also, set a lowpass filter of around 19.5. This will allow Lame to allocate more bits for the audiable range. Use a q (Quality) setting of 0 as well.
Atomix 1.12 had trouble displaying the correct time of the file when I used VBR when encoding the mp3 file. I dont know if it still does that, but it doesn't matter since I encode everything @ 320kbps.
And if you trade alot, do others a favor by encoding at bit rates higher then 190. Theres nothing worse then finding a mp3 you've been looking for a long time, and its encoded @ 128kbps and every single stereo frame is full of warble and tin-ny highs. 128 is NOT cd quality. 190 is near cd quality, with 320 being almost archive quality.
Grimm
Grimm
geposted Sat 13 Apr 02 @ 3:07 pm
That sould be use Joint Stereo (NOT Forced Joint Stereo) and any bitrate 160 or below. If higher, either use Normal Stereo, or Joint Stereo (again, NOT Forced JS).
But Normal Stereo sould really be left for 320 bitrates.
geposted Sat 13 Apr 02 @ 3:10 pm
Yikes. anything faster than 192 is pure overkill, IMHO.
-nate
-nate
geposted Fri 26 Apr 02 @ 12:04 am
