Forum: Old versions
Topic: Gain/Volume Change
When I'm playing a song on A, at the volume I want and drag a new song from the playlist to B, the volume/gain on the song playing decreases noticeably. Can anyone tell me what I can do to maintain a constant volume/gain on the song That is playing. Many Thanx
geposted Fri 17 May 02 @ 5:05 am
Is Auto-Gain enabled or disabled when this happens?
geposted Fri 17 May 02 @ 9:58 am
Re:Volume/Gain question. The same sound/gain decrease occurs with auto gain enabled or disabled. It might have something to do with my 3d sound card.
geposted Fri 17 May 02 @ 4:22 pm
Do you have it set to quadraphonic sound or whatever it's called so that the front and rear channels aren't adjusted or anything by the soundcard-drivers..
Front and rear channels should be equally amplified (=quadraphonic, four equal channels)
geposted Fri 17 May 02 @ 4:36 pm
HomeboyPRO InfinitySupport ManagerMember since 2003
I noticed this in 2.0 not in 2.1 when 2.0 was in software mode. I haven't noticed it in the latest release.
DJ Homeboy
geposted Sat 18 May 02 @ 10:03 am
