is there a way to plug head phone to listen to the next song to adjust the pitch
geposted Mon 20 May 02 @ 8:33 am
With the full version; with the trial, doesn't.
geposted Mon 20 May 02 @ 9:05 am
In the full version you are able to configure your sound options. They allow you to listen to one deck while playing the other, even if you only have 1 soundcard !!
DJ Homeboy
DJ Homeboy
geposted Mon 20 May 02 @ 9:54 am
how does one configure so that it's possible to listen to the next incoming song?
geposted Tue 21 May 02 @ 5:19 am
This Requires the full version.
DJ Homeboy
DJ Homeboy
geposted Tue 21 May 02 @ 5:25 am
It runs not with a crack. Sorry.
NB: hi Homeboy, how are you?
geposted Tue 21 May 02 @ 10:06 pm
Can i egt atomix to cross-fade without always hasving to use the mouse?
geposted Thu 23 May 02 @ 9:02 pm
Yes, setting a shortcut !
geposted Thu 23 May 02 @ 10:27 pm
For horizontal crossfader, I use "delete" and "pg dow". And "insert" + "pg up" for full left and right horizontal crossfader.
geposted Thu 23 May 02 @ 11:01 pm
