Well, it does work, but only on each deck. Could u dj's please help me out on how i can either use atomix with plugins to DJ or just broadcast my "Wave Channel"...
thx. TS
thx. TS
geposted Tue 17 Jul 01 @ 3:44 pm
Yep..... This Forum is Officially Dead. :)
geposted Sun 22 Jul 01 @ 12:43 pm
Yeh...... thx for the replie(s)....... :P
geposted Thu 02 Aug 01 @ 10:43 am
Hy there..i want to know how can i broadcast with virtualdj 3.0 ..do u know how??please reply..tnq
Let the sounds lead your life.
geposted Mon 22 Aug 05 @ 1:19 pm
@anonymous
it seems to be a configuration problem.
Your shoutcast plugin is not "listening" at your master output.
Try to correct this.(it is recommended to select "winamp" as input)
@MicsuniKA: please don't ask the same things in different post.
@MicsuniKA: just start the broadcast and your listeners have to connect to your internet connection IP
http://your_internet_connection_ip:8000/Virtualdj.mp3
You need lame_enc.dll to compress in mp3 if you use shoutcast.
geposted Mon 22 Aug 05 @ 8:13 pm
tnx kaleo i get it now,and i apreciete your help .
geposted Mon 10 Jul 06 @ 6:23 pm
