Forum: Old versions
Topic: Hercules DJ Console -> invalid key with virtual DJ
flixouHome userMember since 2003
Why does Virtual DJ say that I don't have a valid key altough I bought the DJ Console?
I don't have any key in the DJ Console box.
Thank's for your reply.
geposted Mon 29 Dec 03 @ 4:51 pm
...and you don't need any key if you install the VDJ software include in the box.
Coyote
geposted Mon 29 Dec 03 @ 5:01 pm
GwennPRO InfinityMember since 2003
flixou : Where have you found your VirtualDJ install which ask you a serial key ?
Gwenn
geposted Mon 29 Dec 03 @ 5:24 pm
DJ CocoPRO InfinityMember since 2003
write to the customer support !
geposted Mon 29 Dec 03 @ 6:12 pm
Best place find out more about this is to read through some of the many posts from fellow Users of the Hercules DJ Console & "VDJ-lite". main problems at the moment include
1, Speeds up, slows down, spontaneously playback at varying speed and inaccurate editing with Jog wheels (jumpy).
http://www.virtualdj.com/forum/display.html?topic=2593 for info on the hardware/firmware problems and the recall to fix it, they expect you to pay for delivery :-(
2, Software is not "full professional version" as most users believe they were promised, but is in fact a cut down restricted version. and they expect you to pay the full price to get functions that other competing DJ software give for free. Check out http://www.virtualdj.com/forum/display.html?topic=2845 for more info.
Plenty of other software problems (BPM detection, no ID3 tags, clunky interface, stability problems etc (maybe better in v1.08 ???)) but I've twice read that NI's Traktor software will made DJC compatible. So there should be enough motivation to get VDJ sorted, and a way out if they don't.
geposted Tue 30 Dec 03 @ 4:27 am
