Forum: Old versions
Topic: 1 3D soundcard setup - how-to...
vergajoHome userMember since 2002
pls lay down details on setting up a PC with just 1 3D soundcard with 2 line outs for my atomix. i just got myself a FULL VERSION.... yipeeee!!!!!!
more power, atomix!!!!
DENNIS
geposted Fri 06 Dec 02 @ 11:50 am
OyyoDamsPRO InfinityHonorary memberMember since 2003
Please edit your profile and enter your serial number in the required field. You'll then be recognized as a full version user.
geposted Fri 06 Dec 02 @ 1:43 pm
sblondyHome userMember since 2001
with a 3d soundcard you can either connect an external mixer, or connect headphones for monitoring (hearing the song that should come next on the deck that is not used).
External mixer - on a 3d soundcard you have two outputs. connect each output to a different line-in on an external mixer, and configure the sound configuration on atomix to 3d souncard/external mixer.
Monitoring - connect one output to your pc speakers or stereo. the other output you should connect to a set of headphones. in the sound configuration choose 3d souncard/speaker+headphones.
geposted Tue 10 Dec 02 @ 11:27 pm
CRYSTAL CLEAR & PRICELESS, SBLONDY!!!
dennis
geposted Thu 12 Dec 02 @ 9:38 am
