Forum: Old versions
Topic: EQUALIZER [bass fader]
erxonPRO InfinityMember since 2003
I'm not sure how exactly is the equalizer (between both
decks) set, to "smooth" or to "full" functionality, but from
the expirience I believe it should work as a "full" fader.
But recently I noticet, that in some cases (songs) it simply
works as a "smooth", and ONLY on the LEFT deck, which
naturally I don't like :). Enyone else noticed that?
Let me explain:
When I'm mixing 2 songs with the bass fader in the middle,
everything is OK, and if I move the fader to RIGHT_MOST,
it still normally disables the bass frequencies from the left
desk. BUT when I set the fader to LEFT_MOST, I hear a
small increase in left desks' amplitude (in low frequencies).
It's not very significant, and I only noticed it at some songs,
but I'd like to know if that's an "error" in the program code,
and if it is, can it be fixed?
(of course, if the team isn't planning to forget about the
standard equalizer and embed the Kaleo's fantastic filter
effect in the 1.09 VDJ program code? - would be great:)
Best regards, erXon
P.S.: Question 2 Kaleo:
Can the pop-up window of your filter effect be disabled?
It really bothers me, and I don't quite need it :) Thanks!
geposted Fri 30 Jan 04 @ 9:09 am
kaleoPRO InfinityMember since 2003
erxon:
For my plug_in, it's not possible.
You can close the Dialog box (the plug_in still working) but it will appear as soon as you will re-activate the plug_in.
Nevertheless, you can load another plug_in when you don't need my filter.
geposted Fri 30 Jan 04 @ 2:26 pm
kaleo:
Missunderstanding - I don't quite need the pop-up, but the
effect is something I cannot mix without anymore :)
You did make it with the 3 sliders and 4 buttons, which
are enough, and I don't need to see the frequency scheme.
The problem I'm encountering is that I usually turn on/off
the effect quite quickly, since I use it a lot with the fast breaks
(u know, with a bit of resonance,...) not just for long
transitions. So whenever I turn it on and grab the slider,
windows still recognize the pop-up active and VDJ unactive
window, so I have to click on the VDJ first and than change
the slider, and then turn it off... Quite a lot of work :)
But too bad, since you say you made it with pop up only...
Thanks anyway, but I'd still love to see a no pop-up version
if you'll make it :)
Regards
geposted Fri 30 Jan 04 @ 4:37 pm
FruitPRO InfinityMember since 2003
Good idea think about it Kaléo please.
geposted Fri 30 Jan 04 @ 5:19 pm
