Sound volume goes to the maximum level when I run atomix.
Is there any way to retain the settings of the volume when running atomix?
Why is the volume of the samples aren't save after i exit and reopened atomix?
I have creative SB-16 soundcard.
Thanks, I hope you get my problem clearly.
More power.
geposted Sat 11 Jan 03 @ 4:58 am
To disable AtomixMp3 from setting the volume to max when it loads enable multi-instance in the options menu. As for the volume of the effects staying at the same level this is not an option, I will be sure to forward the suggestion for this to the development team.
geposted Sat 11 Jan 03 @ 9:31 am
