Forum: Old versions
Topic: Hercules Running at Warp Speed!
nancybPRO InfinityMember since 2004
Hello, Has anyone had a problem with the hercules controler/virtual dj suddendly spinning playing back the song at warp speed? If so , what is the cause/solution.
Thanks
geposted Mon 02 Feb 04 @ 2:56 am
kaleoPRO InfinityMember since 2003
Please, have a look at the Hercules DJ Console Forum.
You will find the answer in it.
geposted Mon 02 Feb 04 @ 8:57 am
you might be suffering a 'hyperactive jog-dail'.
have your console fixed/replaced by Hercules. (i'm sending mine back this week)
geposted Tue 03 Feb 04 @ 11:08 am
