Forum: Old versions
Topic: visualization mode??
speeedyHome userMember since 2003
my computer is too slow and i have problems running atomix
my qurestion is, how u can take visualization off, i mean visual mix tool on the top of the atomix??
it slows down my computer and i can't do anything
thanks
geposted Wed 02 Apr 03 @ 6:35 pm
abnormPRO InfinityMember since 2003
The waveform display can not be disabled. Try setting windows to lower resolution @ 16 bit color mode, and closing out of any applications running in the background using task manager.
geposted Wed 02 Apr 03 @ 6:57 pm
DJ RickPRO InfinityMember since 2003
You also might want to experiment with several different skins. I think some skins take up more resourses than others.
geposted Wed 02 Apr 03 @ 7:30 pm
av-danoHome userMember since 2003
Hrm. Couldent a skin be made to either a) make a really really small version of the waveform, or b) not have it at all. (i.e. 0 pixels size)
Something to think about.
As for CPU usage, my problem is not that- but rather the fact I have an audigy soundcard, with no new drivers to fix the problem. :-(
geposted Mon 14 Apr 03 @ 8:56 am
PerozPRO InfinityMember since 2003
Yea: you can delete the spectrum analyzer!!!
1) Open the *.xml skin file of your favourite skin (open it with notepad)
2)find something like this in the .xml file:
rhythm
size width="1024" height="80"/
3) set width an height = 0 like this:
rhythm
size width="0" height="0"/
4) save the .xml file
Good luck
Peroz
geposted Mon 14 Apr 03 @ 5:21 pm
DJ CocoPRO InfinityMember since 2003
@Peroz: I am not sure but although you take off that window, atomix still does the same internal process.
geposted Tue 15 Apr 03 @ 5:32 am
Why not remove the entire rhythm-element?
But I think Coco is right... that atomixmp3 will still do the calculations for the rhythm-element. But it's worth a try.
- Jim Nordic
geposted Tue 15 Apr 03 @ 6:21 am
Yea coco: you are right!
However i think it could help anyway, expecially for the videocard.
Peroz
geposted Tue 15 Apr 03 @ 4:21 pm
