Forum: Old versions
Topic: ??? new data base for atomixmp3??? from VDJ??
nashHome userMember since 2003
can you tell me the dif between ...and why there is an installer ...what are the changes?? there is no readme file
geposted Tue 01 Jul 03 @ 7:00 am
Guy, explain a little better please
difference between... : between what ?
and why wrote new database if your question is an other ?
geposted Tue 01 Jul 03 @ 7:45 am
HomeboyPRO InfinitySupport ManagerMember since 2003
I thin you are asking why is there a need for a converter of the internal database ? Well VDJ uses newer technology to scan files but luckily Yan has come up with a converter so you don't loose your database from Atomix.
geposted Tue 01 Jul 03 @ 8:03 am
thats nice ..thanks to Yan
nice
geposted Tue 01 Jul 03 @ 8:11 am
ZaynePRO InfinityMember since 2003
Can someone help me with this converter? I have thousands of songs that I need to convert from Atomix to VDJ.
Thanks
Zayne
geposted Mon 01 Dec 03 @ 10:16 pm
there isnt an exact convertor that'll copy everything!
but there is one that will copy bpms
geposted Tue 02 Dec 03 @ 1:22 am
geposted Tue 02 Dec 03 @ 1:24 am
