Forum: Old versions
Topic: Firmware update for DJ Console
Hercules have just updated the firmware on the console and have an update on their website. They say it is to:-
- Improve Pitch slider sensitivity
- Improve controller latency
Hopefully this will not cause any more problems than it fixes.
geposted Thu 04 Mar 04 @ 10:46 am
1DgafHome userMember since 2004
I wasn't able to download it. There was a problem with the site.
I love it when a plan comes together.
www.idgaf.com
geposted Thu 04 Mar 04 @ 12:27 pm
DJOliveHome userMember since 2004
geposted Thu 04 Mar 04 @ 3:42 pm
Do you just run the file to update the firmware?
geposted Thu 04 Mar 04 @ 5:06 pm
Yes.
Make sure your console is connected to your computer, download the .exe and run it.
When it's finished updated you'll be told to disconnect and then re-connect your console to the computer.
geposted Thu 04 Mar 04 @ 7:03 pm
jonjonzHome userMember since 2003
Just updated to thelatest firmware and no VirtualDJ errors when loading eveytime. Anyone else have this problem or know of a fix?
geposted Sat 06 Mar 04 @ 6:04 pm
I had the same, I rebooted and it worked fine.
geposted Mon 08 Mar 04 @ 11:46 am
YAY !
Me very happy :)
geposted Mon 08 Mar 04 @ 5:35 pm
