Forum: Old versions
Topic: Auto Pitch-Reset not working?
chris_lHome userMember since 2004
Hi all,
I'm confused as to why the pitch isn't being reset when I'm automixing. In the options panel it is definitely enabled, yet the pitch seems to get 'stuck' once the new song is mixed in. Sometimes it'll work for the first song in a set when I load up the program, but from then on it just stays put.
Funny thing was it worked very well when I first installed it.
Are there any other settings that I can use to make sure the pitch slowly goes back to original (other than manually pushing the pitch-reset button??)
cheers
Chris
geposted Wed 14 Apr 04 @ 5:13 am
I think this is related to the crossfader not going all the way to the other side and not triggering the Auto Pitch-Reset...
geposted Thu 06 May 04 @ 4:33 pm
After a bit of investigation, this problem seems to happen when the track is played until the end. The track actually ends before the crossfader reaches the other side. If you select AutoMixEnd: Last beat, chances are that the track will not be played till the end, the crossfader will be able to reach the other side and auto pitch-reset will be triggered!
geposted Thu 06 May 04 @ 5:35 pm
