Hi,
I tried loading the demo on a Toshiba Laptop running win2000pro. I do what appears to be a successful install but upon clicking on the shortcut to open the program I get a popup error that says,
"The dynamic library DINPUT8.dll could not be found in the specified path C:\Program Files\Virtual DJ;.;C:\WINNT\system32;C:\WINNT\system etc.. etc... etc...."
I loaded the demo on a desktop running winXP home and it worked OK.
Any thoughts?
Any thoughts?
geposted Tue 05 Oct 04 @ 12:48 am
Hi,
First, you talk abourt Virtual DJ (www.virtualdj.com) and you are on AtomixM'P3 web site.
Second, update your version of Microsoft Direct X to fix your problem.
Coyote
Coyote
geposted Tue 05 Oct 04 @ 2:28 am
My apologies. I did indeed mean Atomixmp3. I get confused. I will try the DirectX update.
Thanks
Thanks
geposted Tue 05 Oct 04 @ 11:26 am
Wait a minute. The software is called VirtualDJ2 isn't it? It's from the AtomixMP3 site isn't it?
Isn't the link to it right on the top of this page?
geposted Tue 05 Oct 04 @ 11:28 am
It's from Atomix Productions, not from AtomixMP3, and the support for Virtual DJ is on the VDJ web site :)
Coyote
Coyote
geposted Tue 05 Oct 04 @ 4:54 pm
OK... The software that I downloaded from "this" site will not load. I rec'd the message listed in my first post.
geposted Tue 05 Oct 04 @ 6:15 pm
Hi,
Have you installed the last version of Direct X ?
http://www.microsoft.com/windows/directx/default.aspx
Coyote
Coyote
geposted Wed 06 Oct 04 @ 7:00 am
