Topic: please help,2 question
i having 2 type of difficulty here
1)How do i add songs to my already recorded file and connect both of it together WITHOUT having to replay from song number 1 “I like to continue where I stop recording”
2)Atomic save their files as Wav,which is freaking large,how can i convert it back to mp3 with the decent size..
please,your help will be greatly appreciate
geposted Mon 29 Nov 04 @ 5:54 am
first question i can't answer but the second question is easy get a free wav to mp3 convertor online try cnet or whatever search engine you use...
geposted Fri 03 Dec 04 @ 7:45 am
probably the EASAIST one to instal and use is here
http://my.execpc.com/~sfritz/rc-mp3/
it is not the best but it is definatly a good one...you have a lot of setting to play with and best of all it takes up about 500k of space...1/2 meg......nothing...but it performs like a much bigger program...good luck
geposted Sun 05 Dec 04 @ 2:47 pm
as for question one you are going to have to buy a program like "cool edit pro" or something like it...i use cool edit pro to join songs, take out distortion, add effects, remove vocals, re-arrange songs and add beats. if you can't get this program well...you can join, re-arrange and add beats with atomixmp3......just takes longer...
good luck
geposted Sun 05 Dec 04 @ 2:53 pm
