k on VDJ u go live by clicking the go live button where the record button is...it says u can go live with atomixmp3 but there is no button that lets u do so...so how do u go live? i need an answer asap, i have my shoutcast server ALREADY so dont say get a server first...just how do i go live? cuz theres NO button saying it.
-djvesh
happy mixing
    -djvesh
happy mixing
geposted Mon 09 May 05 @ 1:27 pm
          ANYONE??
    geposted Sun 15 May 05 @ 1:08 am
          sorry it took so long to get to you....i thought some one with more knowledge would have responded by now..go here
http://www.atomixmp3.com/forum/display.html?topic=9479
i hope that helps
i hope that helps
geposted Sun 15 May 05 @ 4:33 am
          Can u give me tips on how to mix good i've just gotten started but i know a good bit.This is dj teddizzle
    geposted Sun 05 Jun 05 @ 11:49 pm
          several tips here
1st if possible learn the practical side of mixing on some tables
2nd practice practice and then when you are sick of it practice some more.
3rd buy the program but don't use it until you know how to mix with hardware.then you will truly appreciate how great this program is.
as long as you have the demo you won't be able to use atomix to its full potential. the same stands for a cracked version.
geposted Fri 10 Jun 05 @ 4:49 pm
