Forum: Old versions
Topic: unplug console reboots auto
TreZorHome userMember since 2004
hello
i just went to buy a dj console ,everything works but when i unplug the device from the usb port my system auto reboots.
very strange, i installed the latest drivers en firmware update but i stille have the same problem.
any solutions?
geposted Sat 13 Mar 04 @ 9:39 am
Does it do this when u hot swap any other USB device from the same port?
geposted Tue 16 Mar 04 @ 12:58 pm
kaleoPRO InfinityMember since 2003
TreZor:
Did you try the last firmware and last driver available on hercules website?
geposted Wed 17 Mar 04 @ 7:58 am
i only have it when i unplug the dj console... and yes i installed the latest drivers and firmware update.
i get a blue screen, it says:
IRQL_NOT_LESS_OR_EQUAL error
stop: 0x0000000A (0x0000FFDF, 0x00000002, 0x00000001, 0x806bc90E)
geposted Wed 17 Mar 04 @ 8:41 am
djzeroPRO InfinityMember since 2003
i've had this problem with a few different USB devices. it is some problem in the XP installation. only fix i have found for this is to format and reinstall,
it is typically a problem with the USB root hub drivers but i have not as yet found an easy way to fix this problem
geposted Wed 17 Mar 04 @ 11:57 am
