Forum: Old versions
Topic: Sepia Plugin - Page: 1
I'm having a problem with Kaleo's Sepia plugin... I download it and put it in the video effects folder, but need to add the extention .dll to it, as it doesnt have an extention when i d/l it, however when i load VDJ and go the the settings, i get an error window up saying:
"This application has failed to start because d3dx9_24.dll was not found. Re-installing the application may fix this problem."
I tried d/ling with firefox firstly, but that didnt work (i get the above results...) nut just tried with internet explorer. this brought the whole filename up when d/led (Sepia PS1[1].4.dll) but i still get the above error :os
Any one else have this problem?
geposted Thu 11 Aug 05 @ 9:22 pm
i don't even see the plugin in VDJ after downloading it!
pulled!
@ Basic: I know it sounds stupid, but are u d/lin to the VDJ folder or somewhere else on ur HDD?
@Cyder: Pulled??
Btw, it does it with the "Gradient de Roberts" plugin too... :os what am i doing wrong?? I've not had any probs with the other downloadable vid effects, and im using v3.1
I get the error message for each effect that doesnt work... so 2x for the sepia effect and another 2x for the Gradient de Roberts effect. I have to hit ok, 4 times just to get into the video tab in options!
Hi,
about d3dx9_24.dll, try to re-install directX9.0c.
After this, if the effect does not appear in the list, this means that your graphic card is not compatible.
Which graphic card have you got?
A new version of sepia is ready.
It uses pixel shader 1.0 instead of 1.4.
I hope this will increase the compatibility (most problems seems to come with Nvidia cards).
Ok, I'll try reinstalling DX9c, and i'll try the newer version of the plugin. I have a ATI 9800
It must work really fine with an ATI 9800 :)
:o( couldnt find the dx9c page at microcrap but hadnt really looked too hard, didnt have time. tried d/ling again but still doesnt work. Will keep looking for the dx9c microcrap page and i'll get bk with my results. Hopefully reinstalling dx9c will solve the probs!
I don't think reinstalling DirectX9 C will work because I had this problem with a game called Singles 2 and the game had a fix on the CD for this.
The fix is called DirectX9C update Feb 2005
I uploaded the 32 bit version here
http://sr2.mytempdir.com/115401
And the 64 bit version here:
http://sr2.mytempdir.com/115408
The game had an installer for this but it never worked for me, so what I did was uncompressing the .cab file and then installing the files, I don't remember if I ran "infinst.exe" or if I rightclicked in the .inf file and then clicked on install...
Try and let me know. :)
Use 32 bit version (x86) for non AMD 64 bit proccessors
It's distrubing you admit to having singles 2
Hahahaha, it's not mine, a friend called me to find out what problem he had with this game, so I tried it and found this problem.
No, I hardly play games.
@AlbertoCastillo: thanks for your help :)
Welcome.. tell me if it works :)
@ AlbertoCastillo:
I d/loaded the fileand copied the "d3dx9_24.dll" file into the video effects file in VDJ folder, and its worked, Thanks man! :o)
Glad to help :)
good :)
I still don't have those twop effects showing up in my VDJ. They're in the correct folder and I even restarted my computer. Still no luck.
I now that there is something wrong with nvidia but I don't know that by now.
(I don't have nvidia video card to work on)
Did you try the last version of sepia? It only needs pixel shader 1.0
Have u added the ".dll" extention. If u d/l with firefox, u may need to add the ".dll" part.
right click, select "Rename", and then add the ext. onto the end of the name
91%
