How can i reload a tag? If i change manually tag on a file already analyzed, VDJ doesn't renews to new Tag even though i analize it again....anyway of doing it?
geposted Sat 13 Aug 05 @ 5:35 am
Any help?
geposted Sun 14 Aug 05 @ 12:36 am
You mean id3 tag ?
bacakup your .xml and txt database
and try to delete the mp3's from this two files.
THe reanalyse again. This should work.
Don't forget to switch "read id3 tags" on
And perhaps you had turned "VDJ tag writing on" and therefore VDJ reads
it's speacial tag that seems to have greater priority that original id3tag fields.
If this is the case you can delete BOTH id3 and VDJ tag thru winamp.
Or if you want to alter somenthing try turn VDJ tag write on and
change the tags from within vdj.
geposted Sun 14 Aug 05 @ 12:44 am
