i purchased vertualDJ 2.0 a while ago and everything works properly except i can not get the headphone to work i tryed everything including buying a second 3d sound card with 6 channels but i still get both sounds from speakers and it doesn't say anything about this problem in the user guide..can anybody help me please!!
P.S. again i don't have the trial version i have the registered one so the problem is not that..
geposted Mon 15 Aug 05 @ 12:22 am
you will be probably asked by piracy staff to fil in your serial number to show as a full user on forums.
So it's best to do it now :-)
http://www.virtualdj.com/fusers/modifuser.html
And regarding your problem:
Try the advanced settings where you can assign each card and channel a specific device
(left deck, right deck, prelisten to headphones...)
You can click that images in the sound setup !! not only the windows click-zones!!!
Be sure you have your soundcards set to 6channel mode in your soundcard drivers!!!
geposted Mon 15 Aug 05 @ 12:50 am
